EMona89
5 years agoSimulation waveform editor of Quartus 19.1 problem
Why in using the "Simulation waveform editor" of Quartus 19.1 gives me that the excutable file of modsim is not found. I don't want to use modelsim, I want to use .vwf files to run the simulation.
EMona89
5 years agoWhat should I select to simulate the (.vwf) files?
- RichardT_altera5 years ago
You select the simulator (supported by Quartus) that you need to simulate the (.vwf) files.
You may need to set the path to the simulator executables specified in the Quartus tool under Tools > Options >EDA Tool Options.
Though, Intel highly recommend to use Modelsim-Intel Edition for use with the Simulation Waveform Editor.
Richard Tan
