EMona89
5 years agoSimulation waveform editor of Quartus 19.1 problem
Why in using the "Simulation waveform editor" of Quartus 19.1 gives me that the excutable file of modsim is not found. I don't want to use modelsim, I want to use .vwf files to run the simulation.
RichardT_altera
5 years agoGo to Assignments > Setting > EDA Tool Settings, then specify the simulation tool used in your Quartus project.
By default, it was selected as Modelsim. Do note that you can only select simulator tools supported by Quartus.
Richard Tan
