Simulation Waveform editor difference between input and combinational clock and other questions
Could you please check it again since I am getting different results,
if possible provide the project file(Project->Archive Project)
Vicky
- HTork7 years ago
Hi!
If I'm changing:
quartus_eda --write_settings_files=off --simulation --functional=off.....
to
quartus_eda --write_settings_files=off --simulation --functional=on
I get the same results as you when performing simulation->run timing simulation.
Am I right that this options just turns timing simulation into functional simulation?
That is not what I want to do. I want to see the results after timing is included in the simulation.
Also, I'm using the cyclone 10LP: 10cl025yu256I7G in my design, which is not exactly the same as the one you are using.
I'm sending you the project archieve on email since it seems I can't post it here
- HTork7 years ago
Thanks for the answer!
