11 years agoSimulation Visualiation on Linux
I am using Ubuntu, when I try to use ModelSim-Altera tu run a RTL simulation, I get the messages: Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "/home/eduardp/altera/...
11 years agoHi,
I'm using Fedora and had the same problem. As it turned out, Quartus starts ModelSim, but ModelSim itself cannot run due to some problems; however, Quartus only saw that the ModelSim process started, and reported that everything was successful. What helped me are these two articles: https://wiki.archlinux.org/index.php/altera_design_software#modelsim-altera_edition (https://wiki.archlinux.org/index.php/altera_design_software#modelsim-altera_edition) and http://mattaw.blogspot.de/2014/05/making-modelsim-altera-starter-edition.html (http://mattaw.blogspot.de/2014/05/making-modelsim-altera-starter-edition.html). In a nutshell:- manually execute ModelSim from the shell to see what it tells you; the executable is /installation_path/modelsim_a
- you probably need all sorts of packets to be installed manually
- you probably have to modify the ModelSim startup script (the same file as in my last bullet point), to be compatible with your Linux version
- you probably have to install an old version of the freetype library, because the latest and greatest that is installed with modern Linux distros is incompatible with ModelSim
