16 years agoSimulation Stuck at 49% or 50%
Hello, everyone, My simulation is alway stuck at 49% or 50% percent, and the message says: Info: Option to preserve fewer signal transitions to reduce memory requirements is enabled. The...
16 years ago --- Quote Start --- hey, just a question that how do you increase the simulation duration. I have tried doing it thru settings but it never allows me to increase beyond 1us. neways, try reducing the sim time and simulate. you can also right click on the info and select help. it might give some information as to why that happens. --- Quote End --- Hello, to increase the simulation duration, just go to "edit" then "end time", you can edit the time duration then. The longer the simulation duration is, the more time it is going to take...
