11 years agoactually the test bench is *.vht(*.vt for verilog) even if i use vhd(or verilog) as top, the way i generate the test bench is processing=>start=>start test bench template writer
if find a way to fix the problem: let the quartus generate a vhd file for the sch, then delete the sch file, make the vhd file as the top, then simulate...
