11 years ago --- Quote Start --- Modelsim needs to compile all the components in your design. This message means that you have not told Modelsim to compile the component ex1. Your filename looks a little weird, is ex1.vht supposed to be your testbench file? A more normal convention would be the component source is ex1.vhd and the testbench source is ex1_tb.vhd. But since you said that your top-level design was a schematic, perhaps that it just what Quartus generates. In that case, you may have a problem with your top-level design being called ex1, and your component being called ex1. If that is the case, change your schematic name to ex1_top. Cheers, Dave --- Quote End --- thanks for the help! i am new guy to altera, maybe i am not familiar to the quartus tools, but i feel the simulation of the quartus is not as friendly as ise. how can i do if i want to sim one of the vhd file of the project? is there any manual or handbook for new ones to study how to simu a project? thanks!
