Kurtlin
4 years agosimulation problem
I compiled a AHLD project which works fine, no errors, when I run the simulation (*.vwf)
I get the following error:
# ** Error: (vsim-13) Recompile work.uart_decoder because work.uart_decoder_data_type has changed.
# ** Error (suppressible): (vsim-12) Recompile work.uart_decoder(structure) after work.uart_decoder is recompiled.
# ** Error: (vsim-13) Recompile work.uart_decoder(structure) because work.uart_decoder_data_type has changed.
# Load interrupted
# Error loading design
I deleted all the files from the directory, compile again and run simulation again -> same error!
Thanks for your help
best regards
Kurt
