17 years agohere is my test bench :
LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE WORK.pipeline_package.ALL; ENTITY register_file_tb_ent IS END register_file_tb_ent; ARCHITECTURE register_file_tb_arch OF register_file_tb_ent IS COMPONENT register_file_ent PORT( pd_read: IN std_logic; pd_source1: IN register_type; pd_source2: IN register_type; clock: IN std_logic; flush: IN std_logic; ex_store: IN std_logic; ex_destination: IN register_type; ex_data: IN std_logic_vector(31 downto 0); source1_data: OUT std_logic_vector(31 downto 0); source2_data: OUT std_logic_vector(31 downto 0) ); END COMPONENT; SIGNAL pd_read: std_logic; SIGNAL pd_source1: register_type; SIGNAL pd_source2: register_type; SIGNAL clock: std_logic:= '0'; SIGNAL flush: std_logic; SIGNAL ex_store: std_logic; SIGNAL ex_destination: register_type; SIGNAL ex_data: std_logic_vector(31 downto 0); SIGNAL source1_data: std_logic_vector(31 downto 0); SIGNAL source2_data: std_logic_vector(31 downto 0); CONSTANT CYCLE : TIME := 50 us; BEGIN DUT: register_file_ent port map( pd_read, pd_source1, pd_source2, clock, flush, ex_store, ex_destination, ex_data, source1_data, source2_data); clock <= NOT clock AFTER CYCLE/2; PROCESS BEGIN flush <= '0'; pd_read <= '0'; pd_source1 <= reg0; pd_source2 <= reg0; ex_store <= '0'; ex_destination <= reg0; ex_data <= ZERO; wait for CYCLE; ex_store <= '1'; ex_destination <= reg0; ex_data <= "00000000000000010000000001010001"; wait for CYCLE; ex_store <= '1'; ex_destination <= reg1; ex_data <= "00000000000000000000000000000001"; wait for CYCLE; ex_store <= '0'; pd_read <= '1'; pd_source1 <= reg0; pd_source2 <= reg1; wait for CYCLE; ex_store <= '0'; pd_read <= '1'; pd_source1 <= reg0; pd_source2 <= reg1; wait for CYCLE; END PROCESS; END register_file_tb_arch; CONFIGURATION register_file_tb_config OF register_file_tb_ent IS FOR register_file_tb_arch FOR ALL : register_file_ent USE ENTITY WORK.register_file_ent(register_file_arch); END FOR; END FOR; END register_file_tb_config; What is a .vwf file? I can not find it at the source folder. is it generate automatically when we compile the vhdl file?
