simulate AN812
- 4 years ago
Hi David,
I think the mem_bfm should be the Intel BFM.
I'm not usually use the AN812 design to test the DDR4 and EMIF interface.
The EMIF IP can generate the example design to simulate and test the IP itself.
You can refer to Arria 10 EMIF Design Example User Guide: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20118.pdf
By simulating the example design, you can see all EMIF signals interaction from the memory initialization ,calibration flow and user accesses.
I'm not sure if this something that you trying to get but I'm sure this can give you a good understanding on how the DDR4 and EMIF interface simply work.
Adzim
Hi David,
Adzim
Hi Adzim
Sorry, I should use Questa-Intel. now it is running. and I got the waveform looks very reasonable. but the transcript windows dump a lot of information like this.
why it kept warning. is there a parameter can turn it off, if it now important.
READ Warning: IOAux detected dirty input data.
[2238863560] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: Initiating Read operation from [0x9aab]
# [2238863560] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: READ Warning: IOAux detected dirty input data.
# It is possible that your read operation may contain invalid data.
# [2239014600] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: READ: [0x9aab] => 0x0000000a ( 31 cycles)
# [2241129160] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc420] <= 0x00000000
# [2241280200] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc421] <= 0x00001f00
# [2241431240] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc4a0] <= 0x00000000
# [2241582280] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc4a1] <= 0x00001f00
# [2241733320] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfc380] <= 0x00000000
# [2242035400] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x6080] <= 0x00000008
# [2242186440] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: Initiating Read operation from [0x60c0]
# [2242255860] [DWR=000]: PRECHARGE - C [ 0 ] - ALL BANKS
# [2242337480] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: READ: [0x60c0] => 0x00000013 ( 31 cycles)
# [2242790600] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x6080] <= 0x00000008
# [2242941640] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: Initiating Read operation from [0x60c0]
# [2243011060] [DWR=000]: PRECHARGE - C [ 0 ] - ALL BANKS
# [2243092680] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: READ: [0x60c0] => 0x00000013 ( 31 cycles)
# [2245056200] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x5240] <= 0xffff0000
# [2245509320] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x5280] <= 0x00000000
# [2246113480] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x52c0] <= 0xffff0000
# [2246566600] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4000] <= 0x00000000
# [2247170760] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4800] <= 0x00000000
# [2247623880] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4840] <= 0x00000000
# [2248228040] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4880] <= 0x00000000
# [2248832200] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x48c0] <= 0x00000000
# [2249436360] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4900] <= 0x00000000
# [2250040520] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4940] <= 0xffff0000
# [2250644680] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4980] <= 0x00000000
# [2251097800] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x49c0] <= 0x00000000
# [2251701960] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4a00] <= 0x00000000
# [2252306120] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4a40] <= 0x00000000
# [2252910280] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4a80] <= 0xffff0000
# [2253363400] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x4ac0] <= 0x00000000
# [2253967560] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x50c0] <= 0xffff0000
# [2254571720] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x5100] <= 0x00000000
# [2255024840] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0x51c0] <= 0x00000f0f
# [2255326920] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfe091] <= 0x01000020
# [2255477960] IOAux instance ed_sim.emif_0.emif_0.arch.arch_inst.io_aux_inst.io_aux.inst.<protected>.<protected>: WRITE: [0xfe090] <= 0x7c7f0001
