tiagogioni
4 years agoSimple connection betwenn two ethernet ports on DE2-115
Hi everyone!
I'm trying to connect the two ethernet ports on DE2-115. Basically, I just want to bypass the signal between the two ports without any code/decode protocol. I'am trying to perform thi...
paveetirrasrie_Altera
4 years agoHi,
I believe to transmit the data between 2 port it requires registers configuration setup first but unfortunately the datasheet doesn't provide any information on registers. And Intel does not have any document regarding this device.
Pavee
tiagogioni
4 years agoI managed to get it... it was just a clock issue... no need at all to configure setup.
I thank al attention!!
