tiagogioni
4 years agoSimple connection betwenn two ethernet ports on DE2-115
Hi everyone!
I'm trying to connect the two ethernet ports on DE2-115. Basically, I just want to bypass the signal between the two ports without any code/decode protocol. I'am trying to perform thi...
ak6dn
4 years agoAre you, or are are you not, passing that data thru the two external 88E1111 PHY/MAC devices?
I assumed this is what you are trying to do.
Or are you just trying to connect the two etherNet MAC modules together INSIDE the FPGA device?
I can't tell which from the code you posted, since you don't indicate which signals, if any, are pins on the FPGA, or just internal nodes.
tiagogioni
4 years agoYes! I am trying to pass data through the two external 88e1111 ports, but i didn't get.
I am trying to connect inside the FPGA...
