tiagogioni
4 years agoSimple connection betwenn two ethernet ports on DE2-115
Hi everyone!
I'm trying to connect the two ethernet ports on DE2-115. Basically, I just want to bypass the signal between the two ports without any code/decode protocol. I'am trying to perform thi...
ak6dn
4 years agoHow do you configure the 88E1111 devices? You show no code for that.
I don't believe they will be enabled to transmit without configuration register setup.
