SIGSEGV when executing vcover merge command to merge .ucdb files
- 7 years ago
Segmentation faults are tricky and difficult to debug. I suggest you raise a ticket with ModelSim support and have them look at it. This may have issues with Coverage utilities in ModelSim. If you can why not try using QuestaSim as most issues are already addressed and resolved in the latest version of Questa. I don't think MentorGraphics/Siemens are working on ModelSim that much. May have moved full dev and support from ModelSim to Questa.
Is this version supplied along with the Intel Quartus tools? I think only ModelSim SE 10.5b Intel FPGA edition is provided by Intel. For all other ModelSim versions, please get in touch with ModelSim support staff as Intel do not support other versions.
That being said, a SIGSEGV segmentation fault can occur if the system in question runs out of memory or if the same memory location is being accessed by another program. Check to see if no other program is running or if another copy of the tools are not running in the background.
- AAris27 years ago
That's correct, the version 10.7 is not supplied along the Intel Quartus tools.
Thank you for your information.
Executing the command : vcover merge -64 merge_coverage.ucdb *.ucdb
Failed to open executable ../mentor/modelsim_dlx/linuxpe/../linux_x86_64pe/vcover in execute mode needed for the option -64.
Executing the command: vcover merge merge_coverage.ucdb *.ucdb
Model Technology ModelSim DE vcover 10.7 Coverage Utility 2017.12 Dec 6 2017
Segmentation fault (core dumped)
When I try to merge using the GUI:
# Merge in Process......
# SIGSEGV: segmentation violation
As far as I checked there is no other copy of tool running in the background.
vcover diff, vcover report commands are working.
