8 years agoSignalTAP v16+ and Clock Enable signal problem
I found a nasty problem with SignalTAP on Quartus v16 and up. I've used Quartus v13.1 before and i often used Storage Qualifier signal as a clock enable. I've used "input port" option and clock e...
8 years agoWhat changes or anything have you done to the project as you've moved up in versions? Have you been updating IP and recompiling or are you using a version-compatible database? The feature works so it must be something in your project that has changed or not been updated that is preventing it from working for you.
