echen73
7 years agoSignalTap staus: Not compatible
Issue: In SingalTap, sometime(not always) when I add/remove signals to/from setup window, save-> full-compile-> program device-> Run analysis, the status shows "Not compatible". How to solve this i...
GuaBin_N_Intel
Contributor
7 years agoHow did you program the device after compilation done? Through standalone programmer or in the SignalTap GUI itself. Try to select again the recompiled .SOF before running the signaltap.
