echen73
7 years agoSignalTap staus: Not compatible
Issue: In SingalTap, sometime(not always) when I add/remove signals to/from setup window, save-> full-compile-> program device-> Run analysis, the status shows "Not compatible". How to solve this i...
Abe
7 years agoHi,
Can you tell which device you are targeting and the software version being used. Also a brief description / image of the design would be good to debug this.
echen73
7 years agoYes,
Device: Cyclone V: 5CGFC5C6F27C7
Purpose: QI communication
Design:
- ARM cortex-m0 with peripherals such as: PWM, ASK, FSK, GPIO, UART, with clock enable.
- clock domain: 1pll(82MHz), 1 system clock(divided by 2, 4, 8; from pll, register out)
- echen737 years ago
Quartus Prime Version 17.1.0 Build 590 10/25/2017 SJ Lite Edition
