11 years agoSignaltap retrieve data .... after having plugged JTAG
is it possible to plug the jtag (usb blaster or other) and retrieve captured data (aquire data a postiori) with signaltap? I mean : Program a FPGA with SignalTap, Let the board functio...
11 years ago --- Quote Start --- Because JTAG can set the FPGA into a high impedance which is catastrophic in my system, I can't allow that. --- Quote End --- Only if the TAP machine is programmed to issue the HIGHZ command. Its unlikely to randomly issue this command. --- Quote Start --- I had burnt USB Blasters this way, I think. --- Quote End --- It should work fine. The VCC_OUT voltage from the 10-pin header goes to dual-voltage buffers that are tolerant of either supply powered before the other. Cheers, Dave
