16 years agoGood point. I already checked the "normal" timing of the data that is recorded, but after checking carefully, I realized that there are HOLD-time-violations on altera_reserved_tck. Maybe, this should be a global signal (all of them are already in use). I will check if I can free one global signal for debugging and see if this helps...
Thanks, Thomas
