17 years agoSignalTap II and Linux Installation issues
I am wondering if someone had had any issues while using SignalTap II in unsupported Linux installation. I am using Quartus II 8.0 (SP1) installation on CentOS5.2 with USBBlaster download cable. I have a custom board passed on tome, so I really know little about the board. Everything works perfectly: analysis, compilation etc. The programmer even detects devices in the JTAG chain and gives "successfully programmed" messages if I program the devices. Unfortunately there is no LED on the board which can tell me if the devices have been programmed. So, I tried using SignalTap in my design: added nodes, set trigger conditions, enabled SignalTap in my project and compiled the project. I downloaded the .sof file to the device using the Programmer, opened SignalTap II window and tried capturing the data. However it gave me error saying that the "instance not found" (in the Instance Manager window), "JTAG communication error" (in the Signal Tap II window) and "Download the correct SRAM Object File" in the message console. However I downloaded the correct .sof file several times later on, it still gives the same errors. What could be wrong here? Any help will be greatly appreciated. Sincerely, Kumar Vijay Mishra.
