[SignalTap] How to always keep the latest trigger until I stop the acquisition?
- 4 years ago
I got the solution from the Intel Premier Support.
For reference:
It is possible to always keep the latest trigger occurrence by using segmented buffers and State-based trigger using segment_trigger.
Adding 2 conditions, one REAL condition and one FALSE/DUMMY condition.
The FALSE/DUMMY condition is Advanced and the Result is inputted with a Bit Value set to 0.
The State-based state machine looks like this:
if ( REAL_COND ) segment_trigger; else if ( FALSE_COND ) trigger;It internally triggers a segment at a time thanks to segment_trigger at the real condition (falling-edge in my case).
And the false/dummy condition never triggers. It does trigger only when I click on the stop button.
This allows me to always keep the latest trigger occurrence and is a solution to my question.
I believe sstrell help to answer your inquiries. Do you need further help in regards to this case?
- alexislms4 years ago
Contributor
For reference:
