alexislms's avatar
alexislms
4 years ago
[SignalTap] How to always keep the latest trigger until I stop the acquisition?
How to always keep the latest trigger until I stop the acquisition? I need to see the latest trigger that has happened when I stop manually the acquisition. For example, I have a signal that goe...
  • alexislms's avatar
    alexislms
    4 years ago
    I got the solution from the Intel Premier Support.
    For reference:
    It is possible to always keep the latest trigger occurrence by using segmented buffers and State-based trigger using segment_trigger.
    Adding 2 conditions, one REAL condition and one FALSE/DUMMY condition.
    The FALSE/DUMMY condition is Advanced and the Result is inputted with a Bit Value set to 0.
    The State-based state machine looks like this:
    if ( REAL_COND )
    	segment_trigger;
    else if ( FALSE_COND )
    	trigger;
    It internally triggers a segment at a time thanks to segment_trigger at the real condition (falling-edge in my case).
    And the false/dummy condition never triggers. It does trigger only when I click on the stop button.
    This allows me to always keep the latest trigger occurrence and is a solution to my question.
