amildm
Contributor
4 years ago[SignalTap] How to add signals defined as "wire" in RTL?
Hi All,
How can I add signals, which are defined as "wire" in RTL, to SignalTap ?
Thank you!
- 4 years ago
Well, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
sstrell
4 years agoWhat does pix_data_in_422 connect to? Can you tap anything else ahead of this signal that drives it or whatever it feeds into?
amildm
Contributor
4 years agoActually the pix_data_in_422 signal doesn't drive any logic...
But is there a way it will not be optimized out and be able to be added to SignalTap ? None of the synthesis directives or attributes were able to prevent it from being optimized out...
