amildm
Contributor
4 years ago[SignalTap] How to add signals defined as "wire" in RTL?
Hi All,
How can I add signals, which are defined as "wire" in RTL, to SignalTap ?
Thank you!
- 4 years ago
Well, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
SyafieqS
4 years agoMay I know what version of Quartus are you using?
Is is possible to use latest version and see if the wire is there and can be tapped?
amildm
Contributor
4 years agoI'm using Quartus Pro v19.3.0 build 200.
No, I cannot move to the latest Quartus version because the current project with its IPs is built basing on the mentioned version.
