amildm
Contributor
4 years ago[SignalTap] How to add signals defined as "wire" in RTL?
Hi All,
How can I add signals, which are defined as "wire" in RTL, to SignalTap ?
Thank you!
- 4 years ago
Well, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
sstrell
4 years agoHave you tried erasing the "Look in" setting in the filter? Perhaps you are searching the wrong part of your design hierarchy. Just delete that to try to search the entire design. it's got to be there.
