amildmContributor3 years agoSolved[SignalTap] How to add signals defined as "wire" in RTL? Hi All, How can I add signals, which are defined as "wire" in RTL, to SignalTap ? Thank you! Show Moresstrell3 years agoWell, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
Recent DiscussionsTiming analysis - long combinational pathThe quartus license works with version 25.0 but not with version 17.0Using Reset Release IP (Agilex, Stratix) without IP catalog via simple instantiation is ok?Power Analyzer for Cyclone 10 GXReset Release IP for Agilex needs Stratix 10 device files installed!
