amildmContributor3 years agoSolved[SignalTap] How to add signals defined as "wire" in RTL? Hi All, How can I add signals, which are defined as "wire" in RTL, to SignalTap ? Thank you! Show Moresstrell3 years agoWell, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
SyafieqSSuper Contributor3 years agoYou can find any signal that mentioned in your rtl in the filter, choose pre-syn if the wire is removed
amildmContributor to SyafieqS3 years agoAlso with the per-synthesis filter, SignalTap cannot find the signal:
Recent DiscussionsQuartus did not startFIR IP configured for InterpolationQuartus crashes on long carry chain in Agilex 5 FPGAsQPP 26.1.0 Tools->Generate Simulator Setup Script produces no outputQuartus Prime license rehosted, unable to run
