amildm
Contributor
4 years ago[SignalTap] How to add signals defined as "wire" in RTL?
Hi All,
How can I add signals, which are defined as "wire" in RTL, to SignalTap ?
Thank you!
- 4 years ago
Well, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
