amildm's avatar
amildm
4 years ago
[SignalTap] How to add signals defined as "wire" in RTL?
Hi All, How can I add signals, which are defined as "wire" in RTL, to SignalTap ? Thank you!
  • sstrell's avatar
    4 years ago
    Well, there's your problem. It's getting optimized away. Tap the "upstream" signals that drive this or add virtual pin assignments to the signal in the Assignment Editor.
