amildm's avatar
amildm
4 years ago
[SignalTap] Hot to trigger on the NOT condition
Hi All,
I have a 16-bits bus added to SignalTap.
So, what conditions should I set in the SignalTap so that it will be triggered on any value on the bus, which is different from 0x5555?
Thank you!
  • sstrell's avatar
    sstrell
    Hmm, never thought about doing that. I guess you should check if there is a NOT object when building an Advanced Trigger. Or you could create an advanced trigger that ORs <0x5555 and >0x5555 comparisons.
    Or you could create 2 trigger conditions. The first one would be a basic AND trigger for 0x5555. In the second trigger condition column, you'd set each bit to look for "either edge" transitions so the logic analyzer would ultimately trigger any time a bit switched away from 0x5555.
  • Since there are no feedback for this thread, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Richard Tan
    p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
  • I'm testing the solution, will provide my feedback a bit later.
