gyuunyuu
Contributor
5 years agoSignalTap does not show trigger pulse at the same sample number everytime
In SignalTap II it is possible to specify the trigger position as e.g as centre trigger position. When trigger condition is met, the sample number where the condition was met will always be at the sa...
RichardT_altera
5 years agoMay I know does the sstrell's suggestion help in anyway for your case? Do you need further help on this?
- gyuunyuu5 years ago
Contributor
I cannot share the full design now. I shall see if/when it occurs in a dummy design, I shall share it here.
- sstrell5 years ago
You could just post Signal Tap screenshots, including the Data and Setup tabs. You don't really need to post the design itself.
- RichardT_altera5 years ago
Any update from your side?
Contributor
Please close this item for now as I cannot provide an image to you at this time.
