11 years agoSignaltap: discontinuty length in conditional traces
Is it possible to get signaltap to show a true timeline when conditional storage is enabled? I'm trying to track down some issues with latency on PCIe requests (which can take 256+ clocks at th...
11 years ago --- Quote Start --- I traced a 32bit clock counter. --- Quote End --- That was what I was about to suggest. I did that for these PCIe related traces (see p17) http://www.ovro.caltech.edu/%7edwh/correlator/pdf/altera_pcie_analysis.pdf I was disappointed with the Altera PCIe core, so did not end up using it. Otherwise I might be more help :) I don't suppose you know someone with a PCIe bus analyzer ... I'm sure one of those would trace the transactions and tell you what is going wrong ... Worst-case how about a PCIe host that you can control, eg., an ARM or PowerPC root-complex running U-Boot? You could sequentially perform the PCIe enumeration stages and see where it dies. Cheers, Dave
