11 years agoSignalTap Analyser corrupted signals
Hi there, I am running the standalone SignalTap Analyser as I need to debug a board offshore. I created a SOF file along with a STP file (SignalTap analyser signals). I was able to load the SOF f...
10 years ago --- Quote Start --- What kind of JTAG interface are you using and which OS do you have on the PC running Signaltap? I've seen that kind of problems when running some USB blaster clones under Linux. But the same clone under Windows or a real USB blaster under Linux work fine. --- Quote End --- Sorry for the late reply. I have been away for a little while. I know that they are using a Windows machine but I will check with them about the version and about the USB blaster as well. I will get back to you soon. Thanks for your help, Pierre
