8 years agoSignalTap - II question
problem: Unable to view certain internal registers in SignalTap II i've tried this (added this to my verilog file). i still don't see any of these registers/wire in signaltap. //one att...
8 years agoI've done it in many different versions. I don't think that's the issue.
What filter are you using to find the nodes, pre-synthesis or post-fit? I'd recommend pre-synthesis at first as it by far is much easier to find stuff, you just have to run a full compile. I assume you're able to find many nodes, and it's just a specific one or two that isn't showing up, either because they're synthesized out or because synthesis munges the net name?
