8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All, Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will th...
8 years agoThe effect of instance enable checkbox (only available in newer Quartus versions) can be clarified within one minute by a short test. I'm sure you have found out in the meantime.
--- Quote Start --- Are you sure there is no way to merge STPs? --- Quote End --- There's apparently no supported way. But it's surely possible by manipulating Signaltap XML files.
