8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All, Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will th...
8 years agoWe are several engineers in the project, each one prepares its own STP for the modules/entities...
The problem is in the integration... We should compile the same project with different STP to enable debugiing different units... It's a headach... Is there no way to manage several STP in the same project? Are you sure there is no way to merge STPs?
