8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All, Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will th...
8 years agoForgot about that.
I would guess that the instance would not be compiled into the design. It doesn't make sense to have an enabled checkbox like that and change it after compilation.
