8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All, Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will th...
8 years agoHere is how to enable/disable an instance in the STP:
---------------------------------------------------------------------- https://alteraforum.com/forum/attachment.php?attachmentid=14979&stc=1 ---------------------------------------------------------------------- So, if I disable one of the instances before the compilation, will the instance be not implemented at all? Will I not be able to use it after the compilation?
