8 years ago[SignalTap] -> how to merge SignalTap files?
Hi All, Is it possible to merge several SignalTap files together (Quartus can load a single STP file only)? When I disable an instance in the SignalTap file before the compilation, will th...
8 years agoNo, the files can't be merged, but you can have multiple instances in a single file.
How are you disabling a single instance? I don't recall that option. The whole .stp file is either enabled or it's not, unless you're talking about manual instantiation.
