china_cn
4 years agoSignaltap:waiting for clock
I instantiated 4 Jesd204b IP cores in the program and generated link_clk with IOPLL. When I use link_clk as a sampling signal for signaltap, signaltap shows the waiting clock. And you can see an erro...
- 4 years ago
Probably missing or incorrect timing constraints for the JTAG signals.
Can you check that these signals are correctly constrained?
https://www.intel.com/content/www/us/en/support/programmable/articles/000086649.html
RichardT_altera
4 years agoBased on the KDB, does not seem to be a problem with applying a 33-MHz clock constraint to this altera_reserved_tck pin.
https://www.intel.com/content/www/us/en/support/programmable/articles/000080925.html
