china_cn
4 years agoSignaltap:waiting for clock
I instantiated 4 Jesd204b IP cores in the program and generated link_clk with IOPLL. When I use link_clk as a sampling signal for signaltap, signaltap shows the waiting clock. And you can see an erro...
- 4 years ago
Probably missing or incorrect timing constraints for the JTAG signals.
Can you check that these signals are correctly constrained?
https://www.intel.com/content/www/us/en/support/programmable/articles/000086649.html
RichardT_altera
4 years agoYou can try with different project and see if the same issue occur. If issue persists, suspect maybe something wrong with the hardware.
- china_cn4 years ago
It may be because the hardware is not configured well. I use USB Blaster for downloading as described above (but there is no problem with the downloader), but using the onboard USB Blaster II works fine. I think I'll be able to debug with a USB cable in the future.
Thank you
