signal tap logic analyzer trigger hard coded/programmable
- 4 years ago
It depends on the type of change to a trigger you want to make. Many simple trigger adjustments (level checking, trigger position, etc.) do not require a recompile. To see what changes you can safely make without requiring recompilation, set the lock mode just above the Node List in the .stp file. This will gray out any adjustments that will require recompilation.
Also, by allocating additional node logic resources for tapped signals and triggers (Nodes Allocated options), you can minimize recompile time with Rapid Recompile. Instead of the Auto option, set the nodes allocated to a greater number. After a full recompile, you can then add up to that number of tapped nodes with a Rapid Recompile, which is much faster.
This online training was just updated about reducing recompile time:
Thank you for the information, I now select "allow trigger condition changes only".
