NSuzu3
7 years agoSignal Tap Logic Analyzer feature (capacity).
Question about Signal Tap Logic Analyzer feature (capacity). In the User Guide, the feature is described as follows. - Up to 2,048 channels per logic analyzer instance Does "2,048 channels" mean ...
- 7 years ago
There 's node limitation warning coming out in SignalTap If you have a signal more than 4096 bits
NSuzu3
7 years agoThank you for your support.
I understand the limitation of the total number of bits (sum of all channels) is 4096 bits.
