NSuzu3
7 years agoSignal Tap Logic Analyzer feature (capacity).
Question about Signal Tap Logic Analyzer feature (capacity). In the User Guide, the feature is described as follows. - Up to 2,048 channels per logic analyzer instance Does "2,048 channels" mean ...
- 7 years ago
There 's node limitation warning coming out in SignalTap If you have a signal more than 4096 bits
GuaBin_N_Intel
Contributor
7 years agoThere 's node limitation warning coming out in SignalTap If you have a signal more than 4096 bits
