17 years agoSignal Tap inverting the Bits
Hello All, I had added few signals to the signal tap ( Quartus II version 8.1, Signal tap version 8.1). The strange thing is that some of these signals which are active high in the design ( al...
10 years agoIf you select pre-synthesis signals in SignalTap instead of post-route then I doubt the inversions would show up. I always do pre-synthesis because it's just so much easier to look at, and the signals match your rtl. I've also never seen any signals inverted.
