12 years agoHas it been removed like I said? it is possible to add signal names from code only for the synthesisor to remove them. If this is the case you're viewing a signal that no longer exists, but you usually get warning for this.
Having it as an integer is not ideal for signaltap. see if you can find the signal in the "post synthsis" group of registers. As its an integer it will have made the bus 32 bits wide.
