12 years agoSo, if you have 13.1, you should see the buttons in this order along the toolbar:
"Run Analysis" "Autorun Analysis" "Stop Analysis" "read data" You set the trigger conditions next to the signals you have added to signal tap by right clicking in the trigger conditions column (if single bits) or typing a value (for a bus)
