NJackson
4 years agoSignal Tap causing Quartus to crash
I've recently upgraded to Quartus Standard Edition v21.1. I've noticed that when using Signal Tap, if I try to add State machine nodes, this will cause Quartus to crash and generate an error report. ...
SyafieqS
4 years agoHi Nigel,
May I know if there is any update from my previous reply?
I encountered and error related to quartus locating a script tcl file during unarchiving.
Can you reattach the design with previous issue solved?
NJackson
4 years agoHi,
I've reattached with design with the reference to the tcl file at compile time removed.
This should now compile for you.
