NJackson
4 years agoSignal Tap causing Quartus to crash
I've recently upgraded to Quartus Standard Edition v21.1. I've noticed that when using Signal Tap, if I try to add State machine nodes, this will cause Quartus to crash and generate an error report. ...
SyafieqS
4 years agoNigel,
May I know if there is any update regarding my request
This would be a bug for new Quartus engine with state machine node and stp.
Thus need design to be replicated.
- NJackson4 years ago
I’ve attached the project that I discovered the issue in (it effects other projects as well so appears to be a general v21.1 issue)
