NJackson
4 years agoSignal Tap causing Quartus to crash
I've recently upgraded to Quartus Standard Edition v21.1. I've noticed that when using Signal Tap, if I try to add State machine nodes, this will cause Quartus to crash and generate an error report. ...
SyafieqS
4 years agoNigel,
Is it possible for you to shared the design or small design that able to reproduce this issue? I will check this at my end.
Also, step to reproduce it, you can share via email if it is confidential.
